-   General Tech Help (https://landroverforums.com/forum/general-tech-help-8/)
-   -   Rear Parking Sensors. Hght Adjust, Engine Vacuum... (https://landroverforums.com/forum/general-tech-help-8/rear-parking-sensors-hght-adjust-engine-vacuum-6482/)
puchungozback 04-20-2007 04:00 AM
Hello there, 3 quick question,
First: On my 03' HSE7 Disco when I put it in reverse I get a beep- beep -beep at the normal rate and sound level. I'snt it supposed to get louder and more rapid as I near objects
(cars, etc)??
Second: What is the purpose of the height adjust, I can barely see a difference when I activate it, I thought it would give me a good lowering for loading but all i get is a few centimeters. Do I need a special remote to make it go down further?
Third: Sometimes when i am at a red light or idle for a few minutes I would hear a whinning like a vacuum being turned on and it imedietly turns off. This same noise is when I first start the SUV in the morning but this goes on for about a minute and a half. Is this normal? and what is it?
thanks,,,
Bill E 04-20-2007 06:53 AM
RE: Rear Parking Sensors. Hght Adjust, Engine Vacuum...
I can't help with the first two questions but the third is probably the sound of tthe ABS pump - Should be apparent if you press on the brake peddle a few times it should come on.
Hope this helps.
Disco Mike 04-20-2007 10:30 AM
I can't help you on your first question. The second issue regarding your SLS and raising or lowering it is pretty straight forward. On my 99 D2 when I hit the height switch it will raise the back end by about 2 "s. To be able to lower the vehicle you need to buy a optional remote that's only function is to lower the suspension for easy access or hooking up a trailor.
The question regarding a noise, could be an ACE pump or if you have ACE, a secondary air pump if you have that emission feature.
Mike
