Rover Classic Starting Problem Help!
Hi, I have an 89 Range Rover classic. I am having a problem getting it started. I jump it to get it started and then let it run for a long time to recharge the battery. Then I turn it off and it has no problem starting right up. Then the next morning I will go out to test it again and it on clicks cause it doesn't have enough power to start. I just bought a new battery and that seemed to work for awhile but then over the last week I haven't driven it because of christmas, and now the same problem is back. Any help is much appreciated !! Thanks
RE: Rover Classic Starting Problem Help!
You can't recharge an old battery by letting the engine idle for a bit. It takes usually 2 hours on a charger assuming your battery can be fully recharged.
Go to a local auto parts store and get a free battery load test and be ready to shell out some money before years enf for a new one. |
