Seafoamed Motor, now Service Engine Soon Light Comes on?
Hey everyone, I seafoamed my Discovery II following the instructions I found on this website. Seafoam Induction Procedure - LAND ROVER CLUB V.I.. The motor seems to have better acceleration and it runs smoothly, however my Service Engine Soon light came on. Is this typical? Will it go away eventually? I may take it in to check to see if its throwing any codes. I just wanted to see if anyone else has similar experiences.
Thanks!
Thanks!
Yes. while your engine was choking on the Seafoam it did not run as normal. Probably some P0301, P0302, etc. codes for mis-fires on any or all 8 of your cylinders, and probably codes for the O2 sensors that probably saw some wild readings during the cleaning process and kicked some trouble codes due to the exhaust during that time of "great smoke"!!
Have the codes cleared and go forth!
I sprayed down the engine with some engine degreaser. I made sure to cover up all electrical wires and the alternator. It was due for a cleaning. No problems so far.
