Service Engine Light
I just turned 100k miles on my 96 disco and the dealer inspired Service Engine Light on the right side of the instrument panel came on. Is there a way to turn this light off without going to the dealer? Many thanks!
Thanks Hilltoppersix,
I took your advise and had the codes ran. I had 5 come up:
PO125 - temperature coolant
PO30 - random Cylinder misfire
PO303 - Cylinder 5 misfire
P1313
P1316
I had seen the cylinder 5 misfire code during my last inspection and changed the spark plugs and wires hoping to resolve that issue. Guess not. Any advise you can offer is greatly appreciated
P1313
P1316
I'll save Mike the trouble: you need to run premium gas. 93's preferable, you can probably run 91 if you can get it. 89's borderline, though some people use it. 86/87 is Right Out.
Run a couple of tanks of that through (and maybe a can of Seafoam additive), and then find some place to get your lights reset, and see what happens. (Some people's testers can reset them, some can't.)
Take note: additives that actually *accomplish* something can make things worse... temporarily. Run the additive and a couple full tanks of gas before making any further judgement. I generally put the additive in the take first, on the theory the incoming gas will mix it, but I've heard the other approach suggested as well...
