Strong smell of gas in exhaust fumes
Sure, I may be thinking too hard here...I dont know.
But today i had to pull the Rover ahead to get out my 4 wheeler to plow this G#@ D@&# white stuff AGAIN!
anyway, i started, moved, and stopped the Rover all within about a minute, INSIDE the garage with door open, and noticed a fairly strong smell of gasoline in the air,,,of course i sniffed the tailpipes and they too smelled pretty stong of gas. i will say my snowblower and 4wheeler kind of smelled similar after shutting them down inside the garage so perhaps im just looking for something that is not there...
now, im a generally a diesel guy, been driving a duramax chevy PU truck for years so im not "used to" "normal" gas motor odors, let alone Rover odors.
it is an '08 Range Rover with 30,000 miles on it,,,runs like a clock otherwise. No warnings errors or anything on the dash.
wondering if you guys smell this in your LRs, do they run on the "rich" side, or should i be concerned.
service is due in march so ill be sure to mention it to the dealer since it is still under warranty but perhaps this is routine???
thanks in advance.
thanks in advance.
thanks for reply. yeah, figured as much as well.
after sniffing my wifes tail (pipe) on her navigator last night and my inlaws suburban when they stopped over for a visit (yes, all thought i was ready for the nut bin) last night there is no difference in mine from theirs...smell that is.
let it run awhile in the cold (10 here this am) and the gas odor went away in minutes. slight condensation drip on ground from exhaust tips...smelled and tasted like nothing but water.
so, good to go i figure...
thanks again.
thanks again.
