Hey guys..so open question. 2011 LR4..110k miles. Past few months had a "suspension fault" light and "normal height only" on the vehicle and its literally like a Flintstone car...so low to the ground. It triggered the "don't go over 30" warning once and then, after being parked for 2 solid weeks...miraculously started to raise to normal height again but "suspension fault" amber yellow warning still triggering. Then, today, it drops back down to Flintstone level and says "normal height only" but the 30 mph warning does NOT come on this time and it's drivable. Albeit slowly. I checked fhe 4x4 screen and the left part, which shows the struts and shocks has ONE white little circle thing missing from the left rear wheel. All other wheels have this noticeable white looking circle wrapped around the shock/strut where it meets the wheel. What does this indicate? Local shop wants to replace ALL air shocks w coils..and that's 3k plus. Anyone have knowledge on a cheaper fix for this and what the issue is? (Have not pulled codes from the iid) thanks in advance..
