Sponsored by: CARiD
td5 starter problem
Old Feb 7, 2007 | 02:39 PM
taffy nick's Avatar
4th Gear
Default td5 starter problem
i have a td5 and as soon as you turn the key to ignition lights it starts up and the starter stays engaged while engine runs
Old Feb 8, 2007 | 06:43 AM
austech's Avatar
7th Gear
Default RE: td5 starter problem
you either have a ignition switch problem or a sticky starter, is it only happening when the lights are on or when u crank the engine
Old Feb 8, 2007 | 03:56 PM
taffy nick's Avatar
4th Gear
it happens as soon as you turn on the ignition the ignition lights come on and then it starts up but the starter stays engaged
Old Feb 9, 2007 | 05:39 AM
austech's Avatar
7th Gear
thats a tricky problem possible ignition switch i suspect,
pgaukroger
Feb 29, 2016 05:56 AM
Gimebakmybulits
Jul 14, 2014 05:57 PM
johnkbl
Apr 23, 2012 07:49 PM
trini defender
Defender
Dec 11, 2006 05:14 AM
