Transmission fluid
on
RE: Transmission fluid
Dextron 3 if ine so are the synthetics.
As for draining out all the fluid, no, the ZF tranny does not have a drain plug in the torque convertor so at best you will be able to drain out about 5.5 qts. If your tranny didn't have that much mileage you could try a flush, but with your milaege this will do more harm then good.
My suggestion would be to drain the tranny, add one bottle of Lucas tranny additive and Dextron drive it for 3 or 4000 miles and do it again. This will clean it out pretty well and prolong it's life.
Alos do your regular tranny services at 20,000 mile intervals for longer life.
Mike
Mike
on
If this is the first time, do a filter chabge also. Do you know the procedure for refilling the tranny after draining the fluid, if not, send me your tele number and I'll go thru it with you.
Mike
mikeljacobs@comcast.net
Mike
Thanks to Mike's advise I sucessfully changed my tranny fluid and filter last night. When he says get six quarts of fluid he was not kidding! I used a bottle of Lucas additive then,using the Lucas bottle as an aplicator, I squeezed5 1/2 quarts of Dextron III in to the hole in the pan.
I bought the truck with 30k miles and I am guessing it must have been done at least once since the fluid really was not as dirty as you would think. It didn't really smell "burnt" either. Maybe it's because I only drive it on short trips since I live and work in the same small town. Also, I don't pull a trailer or anything else. Just to be on the safe side I will drain and fill again in the near future.
One other thing though... while I was down there letting the pan drip I greased the driveshafts. Are the only points to grease on the slip yolks and on the regularU joints? I did'nt see a place togrease the double-cardon styleU joints or any places on the steering parts either???
