Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
D2 headers
Old 09-16-2011, 05:35 PM
ekahi_1's Avatar
Default D2 headers
does any one make headers for the D2 i know you can get um for a D1 and saw some thing about doing some headman headers mod a wile back im about to do a cat back system now and would love to do the whole thing...also how much of a differance and power and gas would it be if i was to straight pipe and still use the stock pipes. took off the exhaust from the y pipe and love the sound.
Old 09-17-2011, 07:25 AM
You might try a search on this, I know a few people have talked about it before.
Yes you will gain some more power, not a lot without also reworking the heads so you can move the extra air needed for a bigger power and MPG change.
Old 09-17-2011, 10:03 AM
Street Wolf's Avatar
Edit- I'm staying away from this because the more I read your topic, the less I can really understand what you're asking and wanting to do.
Old 09-21-2011, 06:16 PM
ekahi_1's Avatar
thanks mike your allways a big help...@street wolf i was asking if there was any bolt on type headers for the D2
Old 09-21-2011, 08:34 PM
Long Haul's Avatar
The only difference between the DI and DII headers are the O2 sensor ports. The DI takes a smaller thread then the DII. Im running a DII Ypipe on my DI with universal O2 sensors I dont see why you couldnt use DI setup
Old 09-21-2011, 10:30 PM
Here you go, direct bolt on. Just get the exhaust pipe under the truck mated up to the headers.
Hedman Hedders 39806 - Hedman Street Hedders - Overview - SummitRacing.com
Old 09-26-2011, 04:57 PM
ekahi_1's Avatar
thanks alot long haul thats the kind of answer i was looking for....
Old 10-24-2011, 12:24 PM
calebbo's Avatar
Is that for the D1? The reason I ask is bc it says it's for the 3.5L engine.
Old 01-31-2012, 08:17 AM
drowssap's Avatar
they are for a Range Rover Classic
Old 02-01-2012, 08:34 PM
calebbo's Avatar
Where can I get the D1 headers (link)? and do they mess with any sensors or anything that will throw a code?
Quick Reply: D2 headers
