manifold crack
if i sanded down my exhaust manifold, and aplied a jb weld, would that do the job?
RE: manifold crack
There was a recall on exhaust manifolds for '96-97 Discos...
RE: manifold crack
DO NOT JB WELD IT! Any way, jb weld is a fix in an emargancy I can see, but you need to have a shop try to weld it up, they will tell you it may not hold but it will be better than JB weld. if you JB weld it, theres a good chance if it don't work you won't be able to have it welded. Also check the recall out it will prolly cover you.
Can I take advantage of that recall still? I have acrack developing:)
QUOTE=mikemeyer0;9103]DO NOT JB WELD IT! Any way, jb weld is a fix in an emargancy I can see, but you need to have a shop try to weld it up, they will tell you it may not hold but it will be better than JB weld. if you JB weld it, theres a good chance if it don't work you won't be able to have it welded. Also check the recall out it will prolly cover you.[/QUOTE] |
Call a dealer have them check your vin for recalls, I have mig welded manifolds with good results
Thanks will do
QUOTE=TOM R;425799]Call a dealer have them check your vin for recalls, I have mig welded manifolds with good results[/QUOTE] |
If you need to buy one, I have them used for $50 plus shipping. They are glass beaded clean and thoroughly inspected for any cracks or damage. Any studs are cleaned and all the threads are chased. Let me know if I can be of any help.
Please pm me your info and I will follow up
QUOTE=Paul Grant;426061]If you need to buy one, I have them used for $50 plus shipping. They are glass beaded clean and thoroughly inspected for any cracks or damage. Any studs are cleaned and all the threads are chased. Let me know if I can be of any help.[/QUOTE] |
| All times are GMT -5. The time now is 08:58 AM. |
