Johnson Rods Land Rover Lift Kits and Wheels
Range Rover L322 (2005-2012) Lift Kit
Old 05-13-2017, 02:25 PM
Johnson Rods's Avatar
LR Forum Vendor
Default Range Rover L322 (2005-2012) Lift Kit
For your Range Rover L322 (2005-2012) we have a 2 inch lift kit. The lift will allow for a larger tire such as a 275-55-20 (31.9 inches). Check here for more examples:
Range Rover Lift Kits - Sport and Full Size
Follow us on Instagram @johnsonrods
Here is a 305-40-22
Old 05-17-2017, 04:13 PM
LR Forum Vendor
Time to get ready for those summer trails and install a 2 inch lift kit by Johnson Rods for your Land Rover Mark III L322. This kit will get you the added ground clearance for off road and the ability to fit larger tires. The is the most cost effective and easiest way to lift your Land Rover. Used by 1000's of Land Rover owners since 2010.
JohnsonRods.com
275-55-20
285-50-20
Old 05-23-2017, 09:01 PM
LR Forum Vendor
Another beauty here with 275-65-18 and 2 inch Johnson Rod lift:
On my 2010 Range Rover I'm currently using Goodyear DuraTrac LT tires and I love them! With them aired down a bit and the extra clearance I get from the Johnson rods I have been able to go on some great challenging trails.
Range Rover L322 with 2 inch Johnson Rod lift kit and 275-55-18 tires.
Old 01-10-2018, 02:18 PM
LR Forum Vendor
Start 2018 out right with a 2 inch lift kit for your full size L322 Range Rover.
Check out what size tire you can fit. Have more fun on the trail and improve the performance and look of your range rover. Check our new blog site and link to more:
https://johnsonrods.wordpress.com/
__________________
Please visit our website: https://www.Johnsonrods.com
Follow us on Instagram: @johnsonrods
Visit our vendor section:Johnson Rods Vendor
Old 01-27-2018, 07:11 PM
LR Forum Vendor
Default L322 lift kit and 33 inch tires
Here is a good looking L322 with 33 inch tires and a 2 inch Johnson Rod lift kit.
20x9.5 ET45 Stormer’s
Goodyear Wrangler Duratrac 275/60/20
This build did require some modification to fit.
Build by Stewart's Automotive
Get your Lift kit here: Range Rover Lift Kits - Sport and Full Size
Check out our new blog site:
https://www.johnsonrods.com
L322 with 2 inch Johnson Rod lift kit, 33 inch tires
__________________
Old 02-13-2018, 11:56 AM
LR Forum Vendor
Need larger tires for your Range Rover L322, check out our website for a 2 inch lift kit.
You can easily fit a 32 inch tire and 33's with some mods.
Get your lift kit from Johnson Rods: Range Rover Lift Kits - Sport and Full Size
__________________
Old 02-17-2018, 12:47 PM
LR Forum Vendor
This L322 has 265-65-20 tires (34 inches) and a 2 inch Johnson Rod lift kit.
Note that cutting of plastic and moving of the windshield wiper system was necessary. Build by Wheel Tech Tuning, Glendale CA
If you don't want to do that much work, just get the kit and go with 32 inch tires.
Check our website: Range Rover Lift Kits - Sport and Full Size
Range rover with 34 inch tires and Johnson Rod 2 inch lift kit. Mods required
__________________
Old 02-22-2018, 11:22 AM
cdcohen's Avatar
Do you have any customers running a 275/60/20 on a 20x8.5? The 20x9.5 Stormer is a RR Sport wheel I'm guessing, but I can't find that offset (all are like 53-58). I'm curious about all that was needed to make that setup work with the 275/65/20 (ie: where does the windshield washer system get relocated to). Thanks for posting all these pictures online - the L322's look so good with a 32-34" tire and I'm looking forward to ordering your product for my wifes new-to-her '11 RRSC
Old 03-05-2018, 12:16 PM
LR Forum Vendor
Default Range Rover L322 with 265-60-20 and Johnson Rod lift
Here is a L322 with a 2 inch lift and 265-60-20 (32.5) using 30 mm wheel spacers:
Go to our website to order: Range Rover Lift Kits - Sport and Full Size
__________________
Old 03-14-2018, 10:05 AM
GentlemanDriver's Avatar
4wd High
Do you have any additional information on these wheels? I'm looking for an 18" wheel that could work with a 2010+ HSE, and this is the first I've seen other than the Compomotive. Your L322 looks great. Thanks!
Quick Reply: Range Rover L322 (2005-2012) Lift Kit
