"Soft" brakes pedal..?
last week while at a trafffic light, noted brake pedal to become "soft" and travel longer, but the car would brake just fine, only you'd have more pedal travel distance.
Dealer found "air in the system", bled the system, seems OK now.
I can't understand how the air got into the system?
3 mo. ago I changed pads and rotors, but I never disconnected the calipers.
Credit to the dealer, they did not try to blame the problem on my new self-instralled brakes .
Any one with a thought?
thanx
thanx
RE: erer"Soft" brakes pedal..?
ORIGINAL: tacomatech
Did you crack the bleed screws open when squeezing the caliper pistons back into their bores? If you did, which is good, you might have not closed them soon enough, allowing air to enter the system. I have done it before without realizing it.
OK. The bleeders need to be opened on these when squeezing the pistons back in(shut before you stop squeezing to keep air from getting in). Unlike focus's and malibu's and other common vehicles, these vehicles are sensitive about having fluid pushed back up the circuit. In doing so, an internal leak may have been caused in the process.
Thanks
The brakes feel fine now, I was told they (dealer) bled Master cylinder as well. I hope I did not cause any permanent damage,
Thanks a lot for your help-I will open bleders next time I do the brakes.
PS
Strangely, I never had any problems doing brakes on 2005 Volvo XC90-never opened bleeders there.
The brake pads on LR2 are the same as on 2007-08 Volvo S80, I thought the system is very similar.
PS
