'08 LR2 Misfire
My '08 LR2 seems to lose power on the highway. At a steady speed it jerks/pullsback...like something clogged the engine or gas line. I see posts about misfires...not sure who a misfire feels or what that means.
I took it to the dealership to get them to look at it and during the drive test they told me to change the sparkplugs first. I did that and the same thing happened. I bought genuine LandRover sparkplugs so did I need to gap them? I thought they would come gapped correctly. Anything else I need to try before taking it back to the maintenance. |
Have them check the PVC valve. That's what happened to mine.
Pvc
What is the PVC?
I think he meant PCV Valve
Let us know if you find a PCV valve on your LR2. I've never found one on mine. I recall reading somewhere that instead of a conventional PCV valve, there's some type of emissions device integrated into one of the hoses. Sorry I don't have more specific info on this.
PCV valve on this engine is built into the camshaft cover-cover, large black plastic housing on top of the engine, directly behind the coils.
Generally coils are the reason for misfires on this engine, but plugs are always a good maintenance repair if not recently changed. And no, never gap a modern(precious metal) plug, you can easily damage the plating and significantly reduce the lifespan and performance of it. Is your check engine light on? - does it flash when the vehicle pulls power? If no CEL, it's not a misfire, and I would be looking at fueling. These vehicles don't have common issues with fuel pressure being low(usually fine or nothing at all) but the MAFS is a very suspect component, and is the main input when it comes to fuel delivery. Does it accelerate without issue, and only act up at steady speed? what speed? |
Thanks for the additional info on the location of the PCV valve. I just looked it up and it seems to be integrated into the cover with part ID# LR023777. Apparently, you have to replace the entire cover as it's sold as a single assembly.
I had a similar misfire. There was a code for the fuel pressure sender, so the mechanic replaced that.
He also replaced the PCV valve as a precaution. |
If it work's fine in the morning then hesitates when it warms up I would suspect the MAF. Easy to replace.
| All times are GMT -5. The time now is 04:49 AM. |
