2010 LR2 Front Differential Noise
My 2010 LR2 had the rear differential noise. Local mechanic replaced the problem differential bearing to fix this.
Same mechanic states there is noise coming from the front differential as well. While I have seen many posts about the problematic rear differential, the bearing and its noise, I do not see posts about front differential noise. Is this also a known problem? Is it related to bearings? Is there a fix other than replacing the front differential? |
The front unit is called a Power transfer Unit (Volvo calls it an Angle or Bevel Gear) and it has a pinion bearing that can fail just like the rear differential
Take a look at this link for more information. Thanks Paul https://www.freel2.com/forum/topic14659-15.html |
Thanks Paul. I found this link as well:
https://pawlikautomotive.com/2008-la...g-replacement/ |
FYI only
https://www.ebay.fr/itm/Range-Rover-...-/132512124219 I am not in France but, Pointez sur l'image pour zoomer Vous en avez un à vendre ? Vendez le vôtre Range Rover Evoque Front transfert Box, diff reconditioned-Same Day Service HOW CAN I TELL IF MY POWER TRANSFER UNIT / TRANSFER BOX / FRONT DIFFERENTIAL NEEDS REPLACING? A problem with the Range Rover Evoque power transfer unit / transfer box / front differential can show itself in two different ways. 1. You may hear a whining noise from the front of your Range Rover Evoque, a little like road noise, which tends to get louder when you place the Range Rover Evoque under load, such as when you are accelerating - this is the most common symptom. 2. You lose the four wheel drive, so when you need grip the front wheels start spinning and you just skid around, rather than get out of that muddy field - this could also occur if you have a problem with your rear differential or Haldex. |
https://www.roverparts.com/Parts/FDK006
Bearing And Seal Overhaul Kit, Front Power Transfer Case Intermediate Reduction Drive (IRD) For Range Rover Evoque And Land Rover LR2 Price: $199.95 This is a full repair/overhaul kit for the front power transfer case on the Land Rover LR2 and Range Rover Evoque and includes all the bearings and seals needed to complete this repair. Includes: 4x Bearings 5x Oil Seals 1x O-Ring 1x Drain Washer 1x Crush Sleeve Fits: LR2 / Freelander 2 | '08 - '15 Range Rover Evoque 5-Door | '12 - On Range Rover Evoque Convertible | '17 - On Range Rover Evoque 3-Door Coupe | '12 - On |
Bearing only kit:
https://rimmerbros.com/Item--i-LF111...SABEgLNkfD_BwE IRD Bearing Seal Kit - LF1112BM - Bearmach BK 0084 |
John Craddock Land Rover - parts, spares and accessories
https://www.johncraddockltd.co.uk/da...it-no-oil.html Freelander 2 Front Diff Bearing Kit No Oil Part No. DA7213E International delivery available In Stock: This item is normally in stock and ready for dispatch within 24 hours Freelander 2 Front Diff Bearing Kit No Oil NOW £100.43 exc. VAT £120.52 inc. VAT |
Transfer case oil (as posted on the freel2.com forum):
https://www.freel2.com/forum/topic34...nsfer+case+oil Recommended by LR: CASTROL bot 118/95 plus power transfer unit lubricant (all synthetic API GL-5 75W-90) cod. LR003137 1) CASTROL bot 118/95 plus 75W-90 2) Ravenol Transfer Fluid DTF-1 75w-90 3) Miller EE TRANSMISSION 75W90 4) Kroon Oil SP GEAR 1011 75W-90 5) Miller TRX SYNTH 75W90 |
Reference new and remanufactured front transfer case from a dealer:
1 https://dz310nzuyimx0.cloudfront.net...59c31042e7.png Transfer Case 1 LR040657 Differential Assembly NEW $2,939.82 list $2,498.85 sale 1 https://dz310nzuyimx0.cloudfront.net...59c31042e7.png Differential Assembly 1 LR066503 REMANUFACTURED $1,629.00 list $1,384.65 sale |
https://www.dls-uk.co.uk/media/catal...age_394473.jpg
Transfer Box IRD Unit RECON -Freelander 2Part Number: LR040657RExcl. Tax: £570.83 Incl. Tax: £685.00 |
