2010 LR2 Front Differential Noise
Old Jan 8, 2020 | 09:33 PM
jvh2's Avatar
Default 2010 LR2 Front Differential Noise
My 2010 LR2 had the rear differential noise. Local mechanic replaced the problem differential bearing to fix this.
Same mechanic states there is noise coming from the front differential as well. While I have seen many posts about the problematic rear differential, the bearing and its noise, I do not see posts about front differential noise.
Is this also a known problem? Is it related to bearings? Is there a fix other than replacing the front differential?
Old Jan 9, 2020 | 09:35 AM
p_gill's Avatar
The front unit is called a Power transfer Unit (Volvo calls it an Angle or Bevel Gear) and it has a pinion bearing that can fail just like the rear differential
Take a look at this link for more information.
Thanks
Paul
https://www.freel2.com/forum/topic14659-15.html
Old Jan 9, 2020 | 01:04 PM
jvh2's Avatar
Thanks Paul. I found this link as well:
https://pawlikautomotive.com/2008-la...g-replacement/
Old Jan 9, 2020 | 02:32 PM
jvh2's Avatar
FYI only
https://www.ebay.fr/itm/Range-Rover-...-/132512124219
I am not in France but,
Pointez sur l'image pour zoomer
Vous en avez un à vendre ? Vendez le vôtre
Range Rover Evoque Front transfert Box, diff reconditioned-Same Day Service
HOW CAN I TELL IF MY POWER TRANSFER UNIT / TRANSFER BOX / FRONT DIFFERENTIAL NEEDS REPLACING?
A problem with the Range Rover Evoque power transfer unit / transfer box / front differential can show itself in two different ways.
1. You may hear a whining noise from the front of your Range Rover Evoque, a little like road noise, which tends to get louder when you place the Range Rover Evoque under load, such as when you are accelerating - this is the most common symptom.
2. You lose the four wheel drive, so when you need grip the front wheels start spinning and you just skid around, rather than get out of that muddy field - this could also occur if you have a problem with your rear differential or Haldex.
Old Jan 9, 2020 | 07:28 PM
jvh2's Avatar
https://www.roverparts.com/Parts/FDK006
Bearing And Seal Overhaul Kit, Front Power Transfer Case Intermediate Reduction Drive (IRD) For Range Rover Evoque And Land Rover LR2
Price: $199.95
This is a full repair/overhaul kit for the front power transfer case on the Land Rover LR2 and Range Rover Evoque and includes all the bearings and seals needed to complete this repair.
Includes:
4x Bearings
5x Oil Seals
1x O-Ring
1x Drain Washer
1x Crush Sleeve
Fits:
LR2 / Freelander 2 | '08 - '15
Range Rover Evoque 5-Door | '12 - On
Range Rover Evoque Convertible | '17 - On
Range Rover Evoque 3-Door Coupe | '12 - On
Old Jan 15, 2020 | 03:40 PM
jvh2's Avatar
Bearing only kit:
https://rimmerbros.com/Item--i-LF111...SABEgLNkfD_BwE
IRD Bearing Seal Kit - LF1112BM - Bearmach BK 0084
Old Jan 20, 2020 | 08:14 PM
jvh2's Avatar
John Craddock Land Rover - parts, spares and accessories
https://www.johncraddockltd.co.uk/da...it-no-oil.html
Freelander 2 Front Diff Bearing Kit No Oil
Part No. DA7213E
International delivery available
In Stock:
This item is normally in stock and ready for dispatch within 24 hours
NOW £100.43 exc. VAT
£120.52 inc. VAT
Old Jan 23, 2020 | 10:19 PM
Jvh75's Avatar
4wd High
Transfer case oil (as posted on the freel2.com forum):
https://www.freel2.com/forum/topic34...nsfer+case+oil
Recommended by LR: CASTROL bot 118/95 plus power transfer unit lubricant (all synthetic API GL-5 75W-90) cod. LR003137
1) CASTROL bot 118/95 plus 75W-90
2) Ravenol Transfer Fluid DTF-1 75w-90
3) Miller EE TRANSMISSION 75W90
4) Kroon Oil SP GEAR 1011 75W-90
5) Miller TRX SYNTH 75W90
Old Jan 28, 2020 | 01:34 AM
Jvh75's Avatar
4wd High
Reference new and remanufactured front transfer case from a dealer:
Transfer Case 1
LR040657 Differential Assembly
NEW
$2,939.82 list
$2,498.85 sale
Differential Assembly 1
LR066503 REMANUFACTURED
$1,629.00 list
$1,384.65 sale
Old Jan 28, 2020 | 01:55 AM
Jvh75's Avatar
4wd High
Transfer Box IRD Unit RECON -Freelander 2
Part Number: LR040657R
Excl. Tax: £570.83 Incl. Tax: £685.00
