Door handle double-pull
Yes, a single press of the unlock button on the remote unlocks the driver door only. A double press unlocks all doors. Getting into the car works as desired. It's getting out that requires the double pull.
I read on one of the Volvo forums that lock settings are a menu item on the radio. But the only menu item on my radio is to set the clock time.
JLR SDD/Mongoose, a gapii tool or similar and edit the CCF; most certainly can be done (pretty sure I have come across it somewhere in the software). At least Volvo gave you access through their radio settings but not Landy.........
If you are so inclined:
https://www.jaguarforum.com/threads/...nstall.108460/
^^^ A 25 amp supply charger & patience are a must; brown pants are optional. I run the virtual v130.
