Led lights
Old Jul 14, 2020 | 12:33 PM
Fredrik1990's Avatar
Default Led lights
Does anyone know if it's possible to fit led bulbs instead of the factory bulbs without getting any warninglights in the dashboard? Just switch the bulbs? Or if doesn't work without special adapters or connections? About to change the bulbs in the headlights full beam, position lights in front lights, sidemirror lights(under), reversing lights and also reg plate light.
car is an 2008 freelander2
thankful for help
Old Jul 14, 2020 | 04:29 PM
flybd5's Avatar
I know that on my BMW touring bike I can't install LED lights without modifying the control box. But that is not the case with the LR2. You should be able to install them with no modifications as long as they are designed for automotive use.
Old Jul 15, 2020 | 09:31 AM
Thank you. I think I will try it out then
dbeard
Mar 1, 2020 11:56 AM
jvarnadoe
Mar 22, 2016 05:11 PM
sickws6
Jan 19, 2016 12:22 PM
s10lowrider1994
Jan 4, 2012 09:14 AM
inabinn
Aug 14, 2007 08:19 PM
