Location of Bluetooth Control Module
Can someone please tell me where the Bluetooth Control Module is located in a 2008 Land Rover LR2/SE? I have that it is located in the back, where the tire is, on the passenger side? I've tried to find the schematics online with no luck? I need specifics! Where it is? How to get to it? And what does it look like? Thanks
Bluetooth uses very little current. If the fuse has blown most likely there is a problem with the wiring somewhere, shorted to ground or something like that. Not as common is the box getting wet or damaged.
cmb6s
Jul 13, 2019 10:11 PM
