2 Attachment(s)
Originally Posted by LR2driver
(Post 556998)
This might help. Here is a link to a post I made showing my original diff. You could compare with your current one to see if there are any differences, but not sure how different the replacement unit looks.
https://landroverforums.com/forum/lr...43/#post440298 I just noticed that my pics where on my old isp showing the new rear. I'll have to upload them again somewhere. It's pretty easy to see the difference the new differential is held together by studs instead of bolts. Hopefully that's standard so that you can easily tell. Oh and If you're approaching 90k throw a torx driver in your car for the steering column lock that will fail on you soon leaving you stranded. It's just two bolts under the column to remove the cover then you can give it a couple whacks with something to free it up. Should get you home. Here are pics of the new rear and steering lock. |
Hi Oliver,
Do you have any experience with Haldex failure? Thanks! |
Originally Posted by lutk87
(Post 557213)
Hi Oliver,
Originally Posted by oliver1071
(Post 557111)
