LR2 starting issue SLUGGISH
I have a 2010 LR2. 166k miles. Great service history. Recently when I push start the vehicle, it starts promptly. But the engine sounds like it wants to stall and barely runs. I turn off the vehicle. I press the push start a second time and all is fine. This engine shaking/sluggish activity doesn’t happen very often. But it did so both times I started vehicle today. THOUGHTS WOD BD APPRECIATED.
Originally Posted by ggushee
(Post 726877)
Thank you for your reply. I will have it properly checked. I only have a KONNWEI KW210 Battery tester. I did the CCA test. Its a 790 CCA. The results came back as "GOOD BATTERY".charge 96%. Healthy 5%. Is this ok? But I'm new at all this DIY stuff.
Are you hot soaking your LR2 with the key docked?
if yes take a look at this link https://www.freel2.com/forum/topic29...light=hot+soak good luck Paul |
Thank you. Great article. This is what i think is happening. And it usually does so when i stop to fill up and other short stops. I will now try to remember to withdraw the key fob from the dock each time i shut off the car for short stops. Thanks again.
