LR2 turbo replacement
Hi Monkey - no changes as far as I know but I've not had to put another one in since the last episode at 42k miles - now at 70k miles. There are some super-cheap options out there but due to the hassle that could be caused by a poor quality unit I'd only go with the Borg-Warner (thats OEM) and the cost is about $1k. Good luck.
Updated turbo/exhaust?
Anyone know if the new replacement turbo/ exhaust manifold has been updated?? Looking at a 2013 LR2 w/ 145,000M for my daughter. This vehicle has the P0299 code, so I'm assuming the turbo is junk. Haven't looked at it yet. Just figured I'd ask before going to look at it.
I'm a heavy equipment mechanic so yanking the old one out and stuffing a new turbo/ exhaust manifold in is within my capability.
I know this an old thread, just figured I'd ask. Thank you!!
flyingscot (09-13-2022)
Thank you for all of the quick responses!!!
Hi Monkey, the only update needed was a stronger and better weld on the exhaust manifold. I gotta assume the original units all had a bad weld as the replacement units all seem to be holding up just fine. You’ll know if that is the problem as you will smell exhaust fumes inside the cabin with the heat on. But a P0299 code could also appear from an exhaust leak anywhere along the exhaust system or from a bank 2 defective O2 sensor. You need to take the turbo heat shield off. If the backside is black from exhaust that confirms the weld is leaking. 2 options both involve taking the turbo out (4 hour difficult job for a geed mechanic); replace it with a new OEM unit, or fix the weld on the old one if you think it is working fine. Suggest you Do not but an aftermarket unit on eBay as they maybe an inferior product. There are LR factory parts wholesalers on line where you can get a good price on OEM. My research found that the Ford unit is a different design for placement on the motor.
Fun fact............I own a 97 LR Discovery. Sadly, the rust has eaten away at the machine and it sits in an unused state. My daughter had wanted to bring that back to life. Too much rust, not enough time.
I ran a search for the part number for the turbo/ exhaust manifold. One result was from Ebay. Geniune Borg Warner OEM part..............$1400...........expedited shipping from China!! LOL I've dealt with a few owners who want to save money and get the parts themselves only to end up with cheap chinese knock offs that fail shortly after the arduous process of install.
Borg-Warner turbo
Hi flyingscot, my mobile mechanic who used to work at Land Rover and is an excellent mechanic is reluctant to put in a non-Land Rover made turbo as he says the tolerances are very tight, and says he highly recommends going with the Land Rover turbo. However you seem to have had good luck with your Borg-Warner. What year is your Evoque? Where did you buy your turbo? Have you had any issues? How many miles on the new turbo?
guy (11-03-2023)
