Water elbow pipe replacement
This tube over time fills with oxide. buy a second hand piece and remodel it.
https://cimg1.ibsrv.net/gimg/landrov...683c094ba.jpeg Remodeled it! https://cimg0.ibsrv.net/gimg/landrov...ca3530bb2.jpeg https://cimg3.ibsrv.net/gimg/landrov...b064b84e2.jpeg Pipe elbow installed installation: remove the a / c compressor, remove the large pulley below the a / c compressor (to remove it play make a lock nut between screw and screw), remove the entire aluminum hopper. it is not necessary to remove the fan clutch. and the elbow tubing is exposed. Install with its rubber ring and a high temperature silicone base. It is good to clean the inside of the block with pressurized water, removing the lower hose that enters the radiator |
