Water elbow pipe replacement
Old Oct 7, 2020 | 11:32 AM
muffin man's Avatar
Default Water elbow pipe replacement
This tube over time fills with oxide. buy a second hand piece and remodel it.
Remodeled it!
Pipe elbow installed
installation: remove the a / c compressor, remove the large pulley below the a / c compressor (to remove it play make a lock nut between screw and screw), remove the entire aluminum hopper. it is not necessary to remove the fan clutch. and the elbow tubing is exposed. Install with its rubber ring and a high temperature silicone base. It is good to clean the inside of the block with pressurized water, removing the lower hose that enters the radiator
nevillusa
Sep 14, 2020 11:25 AM
LONERANGER7010
Feb 17, 2020 01:06 PM
Nigelw
Build Threads
Sep 18, 2019 07:14 AM
georgep
Jan 2, 2012 10:32 PM
