2006 lr3 rear diff question
Old Oct 23, 2012 | 04:48 PM
khentige's Avatar
4wd High
Default 2006 lr3 rear diff question
Brought lr3 to garage to get rear locking diff replaced after much noise. Ordered the replacement diff. A non locking diff arrived. I was than told there are no like no locking diffs available. They said they could install it in place of the locking diff and reprogram to disable the rear locking function. But they were not sure if the gear ratio was the same. Anybody every try this? Any thoughts?
Thanks
Eric
Old Oct 23, 2012 | 05:45 PM
ghengis86's Avatar
No, never heard of this. What was the cause of the problem? What did the shop tell you was wrong? Symptoms? I would think it could be rebuilt or a locking diff found.
Did they tell you they ordered the non-locking diff or did they just order it and tell you later?
Old Oct 23, 2012 | 08:14 PM
khentige's Avatar
4wd High
Symptom was a whinning sound at lower speeds. Almost like i had a different size tire on one back side. Also was noticibly louder on highway. When i had it at dealer for 75k maintenance they alao told me i needed a rear diff and if i didnt change it it would keep fetting louder and eventually go. They offered to do it for $2700. I declined. They were right about it getting louder though so after a few months i brought it to a local shop that works on many euro high end vehicles. They agreed it needs a rear diff. Said they can get a uses one for $900 and install would be about 4 hours labor. So for $1500 it didnt sound to bad. They gave me a loaner and off i went. They assumed i had a non locking diff i guess and ordered it. Next day when rear diff arrived they realized it was not right. Told me they cant find a rebuilt one.
Old Oct 23, 2012 | 09:34 PM
ghengis86's Avatar
2005-2009 LR3 Differential Assembly (Locking) - Rear
give them a call; might be able to give you more information as to why the shortage and if there's any hope of getting the locking diff.
non-locking below:
2005-2009 LR3 Differential Assembly (Non Locking) - Rear
or try e-mailing trevor at RovahFarm.com; he should be able to give you the low down
trevor@rovahfarm.com
nh9095
Jan 14, 2019 12:36 AM
mitschweigert
May 15, 2014 05:34 PM
rainydays
May 29, 2012 12:28 PM
Bean
Jul 15, 2010 11:13 AM
MagnaflowRep
Headers, Intake, & Exhaust
Sep 2, 2009 12:26 PM
