Access height auto when in park?
LR3 workshop manual only describes the key fob operated raising/lowering of the vehicle.
See Note 2 from the manual:
OPERATING MODES
The driver can manually select, using the air suspension switch, one of four ride states:
l ON-ROAD - this height is the normal operating height of the vehicle
l OFF-ROAD - this height is higher than the on-road height and provides improved ground clearance, approach,
departure and breakover angles
l ACCESS - this height is lower than the on-road height and makes entering and exiting the vehicle easier for the
occupants
l CRAWL (Locked at access) - this height allows the vehicle to be driven at the access height at low speeds to provide increased roof clearance in low car parks etc.
NOTE: Vehicle height changes are prevented if the air suspension control module receives a 'Door Open' signal from the Central Junction Box (CJB).
An additional 'TRANSPORTATION' mode is also available but is only selectable using T4.
Note 2: An additional function allows the vehicle to be raised or lowered from outside of the vehicle when the vehicle is stationary. This assists with the attachment of a trailer and is achieved using the buttons on the remote handset and the ignition switch in the off position. The remote handset can be programmed to perform a number of additional functions. For additional information, refer to Handles, Locks, Latches and Entry Systems (501 -14 Handles, Locks, Latches and Entry Systems)
OPERATING MODES
occupants
angrylobster
12-29-2014 05:35 PM
0304Disco
10-15-2012 05:16 PM
