ACE Stability Control
Hi, how would you know if your LR3 has ACE Stability control? Also why can you not use Poly Bush Anti Roll Bar bushes? How do they differ from the normal rubber ones?
None of them have it. Supercharged RRS sports do.
Originally Posted by abran
(Post 604354)
This and other Atlantic British videos you can look up explain all this. What Is ACE, DSC And Vehicle Dynamic Suspension?
http://www.roverparts.com/resources/...fluid-service/ http://www.roverparts.com/resources/...-dsc-equipped/ The lr3 does the same thing but uses the air suspension to achieve it. |
Hunmm, OK.
There will be an extra hydraulic pump on the drive belt assembly, and there will be hydraulic lines running into the swaybar assemblies. Also of course there will be another reservoir for hydraulic fluid for these. Ive never seen it on a 3 or sport that was not supercharged. |
I have never seen Active Stabilization on an LR3, it isn't in the L319 Workshop Manual nor do I see parts for it in Microcat. So hate to be "that guy", but I'm going to say it didn't exist in the LR3.
Originally Posted by LR Techniker
(Post 604364)
Originally Posted by Coleroad
(Post 604366)
Like I said, the lr3 used the active air suspension to control body role. There was no need at that point for a hydraulic system.
(Post 604367)
That was in response to another post.
(Post 604364)
