ACE Stability Control
Old Apr 26, 2017 | 06:25 PM
GBR.R's Avatar
Default ACE Stability Control
Hi, how would you know if your LR3 has ACE Stability control? Also why can you not use Poly Bush Anti Roll Bar bushes? How do they differ from the normal rubber ones?
Old Apr 26, 2017 | 06:36 PM
abran's Avatar
None of them have it. Supercharged RRS sports do.
Old Apr 26, 2017 | 06:53 PM
GBR.R's Avatar
apparantly some do it was an option on HSE's there are some threads on Here and on the D3 UK site that say they have it fitted.
Old Apr 26, 2017 | 07:40 PM
Coleroad's Avatar
This and other Atlantic British videos you can look up explain all this. What Is ACE, DSC And Vehicle Dynamic Suspension?
http://www.roverparts.com/resources/...fluid-service/
http://www.roverparts.com/resources/...-dsc-equipped/
The lr3 does the same thing but uses the air suspension to achieve it.
Old Apr 26, 2017 | 07:48 PM
abran's Avatar
Hunmm, OK.
There will be an extra hydraulic pump on the drive belt assembly, and there will be hydraulic lines running into the swaybar assemblies. Also of course there will be another reservoir for hydraulic fluid for these.
Ive never seen it on a 3 or sport that was not supercharged.
Old Apr 26, 2017 | 08:03 PM
LR Techniker's Avatar
I have never seen Active Stabilization on an LR3, it isn't in the L319 Workshop Manual nor do I see parts for it in Microcat. So hate to be "that guy", but I'm going to say it didn't exist in the LR3.
Old Apr 26, 2017 | 08:14 PM
Coleroad's Avatar
Like I said, the lr3 used the active air suspension to control body role. There was no need at that point for a hydraulic system.
Old Apr 26, 2017 | 08:40 PM
That was in response to another post.
Old Apr 26, 2017 | 08:48 PM
Coleroad's Avatar
It was meant to back up what you were saying . Guess it didn't come across the right way.
Old Apr 26, 2017 | 09:10 PM
abran's Avatar
thank you for being "that guy", as I was trying myself not to, you saved me!!!
