Adding coolant every 6 months - too often?
Old Feb 7, 2008 | 06:04 PM
Max_A6's Avatar
Default Adding coolant every 6 months - too often?
I'm getting LOW COOLANT message again, approx 6 months after I had to add couple of litres due to low level. Seems a bit too often to me consideringnoheavy driving.No leaks on the ground,
Anybody had the same problem?
Old Feb 8, 2008 | 07:22 AM
drzjoint's Avatar
Default RE: Adding coolant every 6 months - too often?
i had a coolant sensor go out i guess that is common but also when i checked it. the level was fine.
Old Feb 8, 2008 | 02:26 PM
jimbiram's Avatar
With the 2005's there was a TSB for the replacement of the coolant sensor. There have also been some cracks occasionally found. Check with Dealer.
Old Mar 5, 2008 | 01:19 AM
Max_A6's Avatar
well, the problem was in sensor, which was replaced under warranty.
Old Mar 5, 2008 | 08:52 AM
Never assume, when it comes to a Rover. Coolant levels, from a sealed system, are not supposed to drop and new engines are way to expensive,
Mike_C
Jan 9, 2011 09:44 PM
NiteTrain
Oct 28, 2010 04:44 PM
Tapper
Mar 1, 2010 10:21 AM
kcferna
Jun 24, 2009 03:39 PM
Freelanderfree
Freelander
Mar 28, 2008 11:04 AM
