Air to Coil Spring
Air to Coil Spring
Hello,
Just wondering what you guys think of removing the air suspension and replacing them with the Coil Springs. I have a 2008 LR3 which is not my everyday driver, as far as off-roading, its mainly just trails, nothing too crazy. Seems like my compressor is going bad so just debating if I should replace the compressor or remove the air suspension.
Thank for all the feedback,
Kris
Kris
I have a coil truck and a EAS truck.
The EAS truck is better performs better in every way but one. The coil truck will never drop to bump stops. The coil truck rides more like a Disco II both on and off road.
I do love the coiler admittedly and that truck has taken me to some amazing places
rovers3 (07-27-2020)
Also had the 06 blow out the front half of the system dropping the front only but didn't count that since it was a half failure.
Another I didn't count was a failed charging system caused the EAS to have a mental meltdown and dump all the air on the trail. System was fine once the battery was charged and the alternator replaced.
It was recoverable, I had to slow down from 70 on the interstate, pull off the road, shut it down and restart the truck. Then it would air back up and make it a few more miles. Then repeat till home.
My coils have never done that. So once again EAS is better than coils except for that.
