Air suspension went out
Old Aug 7, 2018 | 05:42 PM
hmong916's Avatar
3rd Gear
Angry Air suspension went out
Hi i have a 05 lr3 i was driving on the freeway and it just lost all air riding dropping the car on the bumpstop. i took it to the first shop specialize in land-rover they said it was a bad air compressor and wanted 1600 but they could not guarantee it would fix it so i bought one installed it with out success i also tested the old compressor and it worked find. the second shop spent 3 hrs and couldn't figure what was wrong they said there was no leaks so they recommend me to take it the dealership. The dealership took 1 hr and couldn't fins out what was wrong and wanted to charge me $600 to try other ways of troubleshooting but the suspect the control module so i bought one and installed it. the car is still not rising should i just go with spring at this point or does anyone know what else it maybe they didn't say it was the high sensors?
Old Aug 7, 2018 | 05:59 PM
DakotaTravler's Avatar
Its not throwing any codes?
Old Aug 7, 2018 | 07:05 PM
houm_wa's Avatar
Check your brake lights and tail lights. Then change your brake switch. What faults are shown? Red or amber? Any speed or freeway speed only?
Old Aug 9, 2018 | 05:25 PM
hmong916's Avatar
3rd Gear
no code is showing the light is red. but the remote stopped working also the volume up button not chance the radio station and the volume down button now change the radio ban the cruz control stopped working and the transmission sport mode no longer work
Old Aug 9, 2018 | 05:57 PM
houm_wa's Avatar
I guess I'd start by ensuring you have enough voltage. Battery, alternator, etc....
....and then I'd get an IIDTool so you can read the internal codes. If there is a red fault light, there are codes. My first thought was EAS calibration or bad sensor, but that doesn't explain the radio/controls issue. Water intrusion? Has there been any water leaks? Ever feel the carpets are damp?
Old Aug 9, 2018 | 07:12 PM
hmong916's Avatar
3rd Gear
yes i have had that issues for about 2 years until till finger why it was happen from the moon roof the driver side always got wet when it rained but i got it fix and its been a year now since. i also took it the dealship and they say it might be the right control module but they wasn't sure. and wanted 400 keep check thing things. i cont find the iidtool ? e bay has it for 2800???
Old Aug 9, 2018 | 10:11 PM
houm_wa's Avatar
Have to make sure it can be registered to your vehicle, so the EBay seller has to ensure that it's a "virgin" tool.
Sounds like water intrusion has caused corrosion in some of your wiring and that is causing your issues. You can do a search on this forum and find all kinds of info on where to look for corroded connectors and how to fix.
Old Nov 25, 2018 | 08:17 PM
Mityone54's Avatar
Hello,
‘I was continuously getting suspension fault light on all the time. I was quoted a ridiculous price for one strut. So, I converted to a coil suspension and I couldn’t be happier and no more faults to worry about...
Kevindk9
May 26, 2023 06:11 AM
gisrover
Jul 24, 2015 07:16 PM
OregonRR
Oct 31, 2009 12:10 PM
matthewchoo31
Oct 15, 2009 10:33 PM
melsdesk
Sep 2, 2008 11:04 PM
