Alternator concerns
My 2006 LR3 HSE won't crank, and it's been slow-cranking for the past week, indicating to me that the battery is dead or not charging. In addition, other electrically-dependent systems are acting funny. This battery is not that old (2-3 yrs), so I'm suspecting the alternator. The alternator seems to be making noises, much like a bad bearing sound, which has been going on for quite some time.
So...how much fun is it to replace a bad alternator? (I don't want to rebuild it!). Are there any threads on this one?? Thanks in advance! Dan |
Pretty easy. You will need a fan clutch tool to remove the fan.
AB has a vid. Just watched it and they don't remove the fan, to each his own. |
OK, I did a little poking around on the LR3, charged it up, put a voltmeter on the battery while it was running, and realized it was putting out 14+ volts. I drove it down to the local parts joint, they 'tested' it, and it didn't hold a charge.
I had the battery replaced, and I'm back in business. Now I'm wondering: is it possible that the alternator could be functioning intermittently, and end up failing me at some time in the very near future?? |
An addendum to the previous post:
The alternator was replaced in Jan 2014; the battery in Oct 2015... |
You can have the alternator tested.
Anything is possible. Use a multimeter or GAP tool to see for yourself what the car is outputting to the battery while running. |
As I mentioned above, the multimeter showed 14+. I also have a Scan Gauge II that I can connect to the OBD II port, to keep an eye on it while running around. I'll pursue that next...
Originally Posted by djatkinson
(Post 644356)
(Post 644348)
Its very complicated. Normally I have 14+ volts, but I started seeing 13.8 ish in the summer. On a trip though Arizona in 110+ temps my voltage dropped to 12.1 volts.
So, I was sure my Alt was on the way out. Changed it in a parking lot. turns out it was fine but the ECU was throttling the charging as my under hood temps were 150+(black LR3). |
Originally Posted by KMET
(Post 644467)
Hopefully, I can figure it out on my 2006 LR3 HSE... |
