Alternator concerns
Old Apr 16, 2018 | 12:26 PM
djatkinson's Avatar
Default Alternator concerns
My 2006 LR3 HSE won't crank, and it's been slow-cranking for the past week, indicating to me that the battery is dead or not charging. In addition, other electrically-dependent systems are acting funny. This battery is not that old (2-3 yrs), so I'm suspecting the alternator. The alternator seems to be making noises, much like a bad bearing sound, which has been going on for quite some time.
So...how much fun is it to replace a bad alternator? (I don't want to rebuild it!).
Are there any threads on this one??
Thanks in advance!
Dan
Old Apr 16, 2018 | 07:39 PM
abran's Avatar
Pretty easy. You will need a fan clutch tool to remove the fan.
AB has a vid. Just watched it and they don't remove the fan, to each his own.
Old Apr 17, 2018 | 12:54 PM
djatkinson's Avatar
OK, I did a little poking around on the LR3, charged it up, put a voltmeter on the battery while it was running, and realized it was putting out 14+ volts. I drove it down to the local parts joint, they 'tested' it, and it didn't hold a charge.
I had the battery replaced, and I'm back in business. Now I'm wondering: is it possible that the alternator could be functioning intermittently, and end up failing me at some time in the very near future??
Old Apr 17, 2018 | 12:57 PM
djatkinson's Avatar
An addendum to the previous post:
The alternator was replaced in Jan 2014; the battery in Oct 2015...
Old Apr 17, 2018 | 01:15 PM
DavC's Avatar
You can have the alternator tested.
Anything is possible. Use a multimeter or GAP tool to see for yourself what the car is outputting to the battery while running.
Old Apr 17, 2018 | 01:58 PM
djatkinson's Avatar
As I mentioned above, the multimeter showed 14+. I also have a Scan Gauge II that I can connect to the OBD II port, to keep an eye on it while running around. I'll pursue that next...
Old Apr 18, 2018 | 10:18 AM
KMET's Avatar
Another alternative while running around.
Old Apr 18, 2018 | 02:35 PM
djkronik57's Avatar
Possible. The charging system is complicated (like everything else). What is the voltage now with the new battery? Mine is consistently 14+ volts, so I think that's fairly normal.
Old Apr 18, 2018 | 02:49 PM
abran's Avatar
Its very complicated. Normally I have 14+ volts, but I started seeing 13.8 ish in the summer. On a trip though Arizona in 110+ temps my voltage dropped to 12.1 volts.
So, I was sure my Alt was on the way out. Changed it in a parking lot.
turns out it was fine but the ECU was throttling the charging as my under hood temps were 150+(black LR3).
Old Apr 18, 2018 | 09:56 PM
djatkinson's Avatar
https://www.youtube.com/watch?v=0hmurGNZqo4
I like that idea!
Hopefully, I can figure it out on my 2006 LR3 HSE...
