Battery Upgrade
Old Jun 4, 2016 | 03:08 PM
Chris Schafer's Avatar
Default Battery Upgrade
It's time for me to replace my battery. I was wondering if anyone had a suggestion for an upgraded battery. When doing maintenance, I like to upgrade while I'm at it.
Thanx!
Old Jun 6, 2016 | 12:32 AM
bbyer's Avatar
Default CaCa battery construction suggested.
I use Interstate MTP batteries in my 3. I just replaced my Interstate starting battery with another Interstate; my number two Aux battery is also Interstate.
The replaced Interstate starting battery lasted 7 1/2 years so I figured it did not owe me much. Regarding failure mode, the feeling is after that length of time, it just ran out of internal "water". It got hot and I could smell the battery acid boiling out - that was the clue that I needed a new one.
Starting the engine was not an issue as I have the Traxide dual battery system installed.
There are other batteries out there that use the CaCa style of construction such as the Made in USA Deka brand battery which is also excellent. For me however, there is a local Interstate shop in our village, (no Deka dealer), plus Interstate is what Land Rover specs as a replacement battery.
I mention the CaCa construction as that is the battery internal construction that the regulator within the Denso alternator and the Car Computer is expecting to see.
Regarding battery size, a DIN H8 is called for but I use the H7 as being about an inch and a half shorter, it fits into the battery box easier.
The Interstate description is MTP-94R/H7 and item number is AIB00134
Below is a link to some files related to the battery and charging system.
DISCO3.CO.UK Photo Gallery - Traxide Dual Battery install in LHDrive
nateandnikki
Jul 2, 2013 06:38 AM
xoo00oox
Jan 11, 2013 06:23 AM
antichrist
Mar 29, 2011 08:41 PM
arrkerr
Dec 14, 2005 10:06 AM
jvanbelkum
Nov 4, 2004 05:00 PM
