Brake issue
We just got 32" of snow dumped on us here in Virginia and after plowing through the snow (the LR3 is a BEAST in the snow!) and letting my car sit overnight, I experienced something very strange. When I went out in the morning (or even late at night) to drive somewhere, I had almost zero brakes for the first couple of minutes. And when I say that, I'm not exaggerating.
I have a bit of a slant to my driveway and the first time it happened, it took me by surprise. As soon as I put the car in Drive, it started rolling down the hill with my door open despite the fact that my foot was on the brake. I literally had to mash it into the floorboard in order for it to have any effect at all.
My pads are in good condition as are my rotors. Fluid was flushed just over two years ago, so I suppose contamination is possible, but unlikely.
My question is, has anybody else experienced this? My thought is that it may just be moisture/water freezing to ice on the rotors or pads. It would make sense and would explain why it goes away after a few minutes of driving/usage. However, I'm open to other suggestions or possible causes. I'd also like to know if I'm the only who's had this happen because I certainly haven't experienced it in any other car.
since the rotors retain a little heat I have seen them sit wet in the snow and ice over, but the truck is so heavy it should rip through that no problem. Could be a line pressure or master cylinder issue, leak, Maybe the calibers froze up a bit.
You check the fluid level under the hood? What rotors/pads are you using? Are you running something ceramic like akebono or are you running something like the oem ferodos or textars? I never had issues with stock rotors and textars but you having to mash it to the floor sounds like it may have been too little fluid? Anything ceramic and the initial braking action will need some time to heat up before they brake as good as the bimetallic stuff.
I lived in Fredericksburg the last few years so I can imagine the situation.
I'm running the Akebono Ceramics with factory rotors. I can see them needing time to heat up before performing "well", but this was to the point where I almost couldn't hold my car still when it was in gear on the hill.
Didn't drive through slush or water per se, but I was driving through 30" deep snow. I certainly had some melt on the car. I almost want to just spray my brakes with water the next time we have very cold temps and see if I can replicate the problem.
Thanks for the feedback! Maybe this is all it is then... ceramics are crappy in the cold. I guess I would prefer that to a problem with the braking system. The only thing is that I never noticed the problem in cold dry (no snow) weather. Guess I'll have to experiment some.
Likely just ice buildup on the rotors. I use mine as ski truck so in the snow all the time. I have had that after driving for long periods in wet or snow (not after sitting though). If driving through slush/snow/salt I gently hit the brakes every so often to clear the rotors. Some cars even do this for you automatically. My Audi would clean the rotors in wet weather every so often.
