Broken axle shaft = Dead in the water!
Old 09-22-2016, 02:25 PM
MrWesson's Avatar
Default Broken axle shaft = Dead in the water!
Just a warning to all of you out there. I broke an axle shaft (actually the housing/*****) on a trail 6 hours from home which in itself sucks BUT..
If one axle pulls from the hub then the truck sends all power to that axle..
I was able to limp a short distance keeping the wheel straight in 4LO until the spindle stripped and then I couldn't move or park the truck. This is ridiculous as in any other 4wd I would move with the center locked.
So am I expected to carry 3 spare axles(one rear, two front) to feel confident on the trail?
Old 09-22-2016, 02:57 PM
houm_wa's Avatar
May I ask about your setup and the conditions you were in when this occurred?
....will help in answering your last question.
Old 09-22-2016, 03:33 PM
Best4x4's Avatar
Received 2,297 Likes on 1,688 Posts
We have center locking transfer cases on the LR3, and on my HSE I have the rear e-locker. I would think if you selected the proper terrain mode it would lock the center transfer case, and if it detected wheel spin I'd hope it would engage the rear locker.
I'm new to the LR3 and it's modes, so I may be wrong.
Old 09-22-2016, 03:42 PM
houm_wa's Avatar
Correct. There is no manual lock for either of those diffs but in "Rock Crawl" they are so sensitive that they will be locked most of the time.
Old 09-22-2016, 07:37 PM
Best4x4's Avatar
Exactly what I was thinking
Old 09-22-2016, 08:37 PM
Received 1,590 Likes on 1,306 Posts
I two have ridden in one with a blown axle. Sounded like a bag of hammered butt holes but it got back down the trail. Lockers kicked in and it drug itself home. Maybe his center diff wasn't locking for some reason
Old 09-22-2016, 08:48 PM
MrWesson's Avatar
Rock crawl did indeed get me a couple miles until the axle spindle fully stripped and then trust me its dead in the water. Also keep in mind that home is probably not just down the road and since rock crawl only works in low range and will unlock the center diff in 2nd gear its going to be jogging pace.
Old 09-26-2016, 12:09 PM
houm_wa's Avatar
You never did provided details on your setup. I'd just be interested to see if you are running in any non-typical configuration like spacers or polybushes or something.
Old 09-27-2016, 07:34 AM
MrWesson's Avatar
All stock although I run a lift through the gap tool which may compound the issue/angle but I started a poll to try to get some data.
I also noticed the design can be checked and lubed.
Old 09-27-2016, 02:59 PM
houm_wa's Avatar
Do you run the lift full-time?
Quick Reply: Broken axle shaft = Dead in the water!
