Can I replace my 2008 LR3 wheels with 2011-2014 LR4 wheels?
Old Feb 10, 2015 | 07:20 PM
gillart's Avatar
Default Can I replace my 2008 LR3 wheels with 2011-2014 LR4 wheels?
Hello! I have a 2008 LR3 SE. I'd like to replace the rims with the more modern OE ones from the 2011-2104 LR4. Anyone know if this would be possible?
Suggestions on where to get the new wheels and what to do with the ones I will remove?? Can any local place like Midas do this for me or should I have them removed/installed at a LR dealer only? THANK YOU ALL ! ! !
Old Feb 10, 2015 | 09:01 PM
houm_wa's Avatar
Okay. First check the bolt pattern, offset and axle bore on the LR3 and LR4 rims and make sure they are the same (they ought to be). Then as for where to get the new wheels and what to do with yours, Craigslist is your friend. Also these forums have a Classified section. Finally, what do you mean by "do this for me" with respect to Midas? Do you mean mount, balance and bolt on the new rims and tires? Just go to a Discount Tire or Les Schwab.
Old Feb 12, 2015 | 09:21 PM
mx468's Avatar
Post them on this forum and other Landrover forums in the classified section with pics, What size are your rim/tires. The 18" are the most favorable for our LR3's, due to the better choices of tires in that size to fit our trucks.
gillart
Mar 22, 2015 01:45 PM
gillart
Mar 15, 2015 08:13 AM
gillart
Mar 6, 2015 07:14 AM
gillart
LR4
Feb 13, 2015 09:48 AM
dr.brillo
Jun 8, 2011 06:29 PM
