Compressor and Suspension Question
#22
Originally Posted by jafir
I noticed you have front air springs for the LR3. Do you have any plans to produce the rears?
Originally Posted by Arnott
Thank you for your interest in our parts. We should have something available for the rear towards the end of this year.
#23
Sounds like maybe ten months from now?
The end of 2014 kind of makes sense.
I suppose Arnott is gong to see how the front assemblies work out and the demand for same and proceed on that basis - the approach probably makes commercial sense.
Thanks for looking into it as the Advance website part numbers just seemed odd.
#24
The Arnotts are installed and so far I cant tell much of a difference. When comparing the factory struts to these, The Arnotts seem much better designed and built. I can tell they are a little firmer, but most people wont even notice. So first 24 hours in! Ill post a month review as it comes up and I've used them off road.
#25
#26
good news then re Arnott's
The Arnott's are installed and so far I cant tell much of a difference. When comparing the factory struts to these, The Arnott's seem much better designed and built. I can tell they are a little firmer, but most people wont even notice. So first 24 hours in! Ill post a month review as it comes up and I've used them off road.
I see you have a pretty thorough maintenance program in place. I think that is wise as routine replacement of parts is a lot cheaper than towing and then replacement at a time and place not of your choosing.
#27
#28
Yes, If the service bulletin says it, I try to make sure its done (Using myself and trusty INDY shops of course). Next I plan to add a sump guard in the front and do a tranny flush soon. Only prob is, the LR dealership here and all the INDY shops are telling my not to flush the tranny. So we shall see....
On another note, I have one good LR3/RRS strut for sale if anyone needs one! $125.00
#29
What I've heard on this board and others from all our techs that post is that if there is no current issues with your tranny, then flushing is fine. If there is already some slippage and such, then a flush could make it worse.
I'm not sure what one does, in that latter case...besides just waiting for it to die and then replacing it. ????
#30
Shocks are shocks I figure.
Probably the one bad design aspect of our 3's is that in a practical sense, when you need you new shocks, you best purchase the whole assembly. In theory the air spring rubber is still good except guess where the oil went that escaped the now useless shock - hence one may as well replace the whole assembly. The older FFRR's have the shock separate from the air spring, hence one can just replace the shocks normal like, as is required.
