Cruise Control Troubles
Hello
Im getting frustrated with the electrical gremlins but I digress. Ive got a 2005 LR3 SE. Over the past year the cruise control would either fail to turn on or disconnect after a short period of time. Ive replaced the clock spring and the switch controls on the steering wheel and brake switch and I continue to have the same issue. And Ive replaced the battery within the last 6 months and the voltage is always above 14.1v. Some days are good and I can enable cruise control and it will work flawlessly while other days dont work at all. I finally found the following error code
P0576-16 (2A) Speed control input - circuit low - General electrical failure - circuit voltage below threshold
As soon as I clear this one error code, I can enable cruise control and I wont have the error return sometimes for hours and other times minutes. Does anyone have any suggestions what I can check or what I can do? Im hoping to get this fixed for road trip season. Thank you guys.
I used to have a problem with my cruise control. I noticed that if I turned the key to the on position and let the truck go through all of it's checks before starting the ignition, the cruise would always work as it should. Occasionally, I would hop in and start the truck all at once and when I did that, I would have problems with the cruise control. This may be totally unrelated, but it has worked for me (knock on wood).
Yup its new and it didnt help or make the issue worse. I really do appreciate the thoughts. The GAP cant read the cruise control lamp and when it fails, it wont turn on the lamp. Ill check later and see if it can show more about buttons, Ive never looked that far. Im not sure if its related or not but nearly every single time I start the LR3, I get a Transmission Fault on the dash for maybe 2 seconds and it goes away. I get no CEL or anything in the codes regarding this and it doesnt effect the LR3 is way but it might be related
Ah... trans fault. I bet that is is. Cruise is disabled by list of faults far too long too mention, but it basically expects a perfectly working truck. So any ABD or driveline issues will disable it. If its at startup then its almost always alternator/battery related. I would verify battery voltage before starting. I know you have 14.1 when running which lily indicated the alternator is good BUT does not guarantee its not failing. Alternators start to fail by randomly cutting out and annoyingly the LR3 does not give much of a warning, the battery lights is almost useless. With all that said there is another annoying flaw which is brake lights. One should use proper brake like lamps of good quality as the system is very sensitive to them. When installed the filament should be vertical, if horizontal its the wrong lamp or a poor quality one. So if you have not done the brake lamps in a while, maybe just replace them as another thing to rule out. Certainly cheap and easy to do.
