Delphi tool vs IIDtool
I have the delphi tool mentioned in this post.. https://landroverforums.com/forum/di...through-64554/
It was purchased for around $100 with express shipping and works with most cars via a windows enabled laptop.
I was going through the settings for the LR3(looking to buy one) and found it had most of the settings the IIDTOOL has.. So what makes the IIDTOOL $300+ Better?
Delphi works great for diagnosing most issues.
The GAP Tool can also reflash certain ECUs, so that you can update software (for example if you are replacing/updating the compressor). Aside from that, there is also the customer support aspect.
Edit: Oh... and it can edit the CCF. Don't know if the Delphi Tool can do that.
Sorry if I came across defensive.. Dont feel that way at all. Just trying to gather the differences between the two of them.
At first glance I figured the differences as slight.. I've changed my mind.
That's a huge plus as that seems like a common failure point. If you don't calibrate the sensor does it just not react once installed?
Depends on how close the new sensor reads to the old sensor. If it's close, it will probably work fine and just be a little off on height. If it's not close the computer probably will freak out and not work on that side. I know that's how a D2 works... not sure about the 3.
No worries, Mr. Wesson....
As for sensor calibration. There is a "window" of ranges within which each sensor has to read. There is also a relationship between sensors. I think that having a sensor read out of that range has more to do with it being "pushed out" because of its relationship to one of the others...if that makes any sense. Like if you installed any single sensor independent of the others it would always read in the right range, but when calibrated also with respect to the others, one may be pushed out. That's not a scientific explanation, but that's how it works in practice.
The IIDTool can be used to fix this scenario. There is a detailed process to do so, and if you get stuck the designers and support folks are nothing short of EXCEPTIONAL.
I sing their praises because last year I was in that situation....new shock, new sensor and the dealership, even with their fancy IDS tool could NOT calibrate it. I was a bit nervous...it looked like hell. The LR3 was lopsided, the steering was off....just not in good shape at all. I spend one afternoon with my IIDTool and Christian (Simard) from GAP via e-mail...and I had it NAILED. I mean each corner within 1 mm of each other.
Saved my butt! Not to mention that the failure in the above scenario happend on a trail, and I was able to use the IIDTool to get the LR3 off the bump stops (and my 32" MT/Rs) and back into normal height so that I could pull the EAS fuses.
It's absolutely invaluable. Best two LR3-related purchases ever: RS Sliders and GAP's IIDTool.
