Engine Vibration at 1100rpm
Not sure if this is normal or not, but I noticed that right at 1100rpm in my 08 HSE V8, there is a distinct vibration from the engine. It does this in Park, Neutral, and Drive. In Drive it feels like running over a bit of very mild washboard as the rpms pass around 1100. Disappears at anything below or above that.
Anyone else have a similar problem?
I had similar (with a lumpy idle) when I bought my 08 LR3. Cleaned out the throttle body and the vibration went away. Quick, cheap and easy check. Could be that simple.
Discovery LR3 - Cleaning Throttle Body - YouTube
No codes or CEL. Performance is good. I think it might shake a bit more at idle with the A/C engaged as well, but that could just be me feeling things. Belts and pulleys seem like a good place to start.
