Floor Jack recommendations LR3
My apologies if this already covered but I couldn’t find my answer by searching. Does anyone have recommendations for a floor jack for my LR3 with 265/60 18’s and the stock air suspension? I’d like mainly to be able to easily change tires and am unsure in particular if 18” is enough travel or if I need more. Thanks.
You said floor jack. I have the (orange) Daytona 3 ton model from Harbor Freight. When placed on the frame right in the middle between front and rear wheels, it can lift both of them off the ground no problem . It extends high enough to use the tall 4 ton jack stands at the second or third setting. I would guess at least 18-20 inches high.
For scheduled brake service or suspension work when all four wheel need to be off the ground, I use the 7,000lb Automotive Quickjack. It lifts the whole car a true 24 inches and has always seemed very stable when fully raised.
For fluid changes, I use 4 of those plastic ramps. It gets all wheels raised and makes the car level for checking fluid levels in the transfer case and diffs more accurate.
When working on the interior, I usually wind up lowering the car so it is easier to get in and out.
Hope this helps.
Jeff
Hope this helps.
Jeff
Blesh (09-22-2021)
