how reset computer/display after oil change
I just did my first oil change (including new filter) on my 06' LR3. I've had it about 6 months now and thought it was time. Wondering if there is any reset that I need to do on the computer? In my H2 I have to manually reset the oil-change setting otherwise the H2 wsill warn me that it is time for a oil change. Is there a similar thing for the LR3? I suspect so cause everytime I first start up the LR3, the odomoeter area shows me negative numbers suggesting I am overdue for some service (I suspect the service it is referring to is the oil chnage).
All advice and info is appreciated.
Oh, other than an oil change, is there any other 'important' service that needs to be done on a somewhat annual or semi-annual basis? Other than brakes of course, as this will need to be done once the sensors go off when the pads are low.
Thanks
Thanks
Markster
07-13-2015 06:39 PM
cheqbay1997
06-11-2014 11:24 AM
collin Barrows
08-28-2011 08:13 AM
