LR3: My dual battery / auxiliary battery install
I will update this thread as I finish this project. Today I just fitted the battery into the second bay. This is a US LHD model LR3 - 2006.
The first thing was to get a battery that would fit. Many threads, many comments. Some battery sizes I could not locate in the US. I ended up with a 40R. The size, 40R, has the "euro" top which works with the factory hold-down. And while this battery is physically smaller than the main battery the capacity remains pretty much the same. 800CS, 650CCA. So I have matched batteries. NAPA Auto Parts carries the 40R for $125 USD. If you have a Sam's Club, you can pick up a 40R from Duracell for just $100 USD. You can also use a regular group 40. The R means reverse terminals, which for how I am positioning the battery and routing wires was ideal. This battery is a wet cell lead acid starting battery. Its NOT a deep cycle. Because I dont camp much this works fine. I usually stay at a place for just one night. And even if I stress the battery enough to kill it, I should get at least three years out of it. Battery has a 75 month warranty. I assume the is some prorated coverage after the first year. https://cimg6.ibsrv.net/gimg/landrov...e30fc5033.jpeg But the battery will be wired for jump starting, winch assist, and house power via 4awg lines to the rear. To assist in charging and switching power for jumping/winching the main batter I have a Blue Sea ML-ACR (model: 7622). I bought this particular kit after looking at the popular Traxide solenoid for a couple reasons. First the Blue Sea solenoid was about the same price since I will be making all my own cables. Second, its IP67 rated. This means it can take pressurized water, like from a pressure washer, just fine as well as be submerged for 30 minutes. Traxide fails to mention any IP rating. Third it can operate up to 500amps continuous. I will never push the amp rating that far, but the Traxide is rated for only 160amp and I dont believe continuous. This may not be a big deal, but if I am winching and want all the power I can get I want to be certain its there safely. The best price for these was from Amazon for about $200. It includes a remote switch, standard carling style. I will have to extend the cable. https://cimg9.ibsrv.net/gimg/landrov...a4ed98b02b.png INSTALL: So today I deiced to at least get the battery fitted into the second bay. If you are going for the largest battery that will fit, like I did, you need to make some minor modifications to the battery compartment base. On the forward end there are some support ribs that must be removed. I removed half the base and with careful Dremel work took them off. For the three remaining on the other half base, same deal. I just did so with the base installed. Make sure you smooth things out. The plastic is very hard and I feel its possible burs could cut into the battery shell. Before final install, I will be placing some compression foam to support the battery and snug it up. As you can see in the pics, there is still about a quarter to half inch gap between the battery and master cylinder. I will be installing some dense foam on that side of the battery. I may even insert some studs in the compartment base to prevent the battery from sliding backwards into the master cylinder. But for now I am happy with how much clearance there is. I test fit the cover and there was no issue, plenty of room. The one mistake I made was to purchase a battery hold down for an LR3 that stated it was for the second bay. They are not the same, you need different holders for each side. So I am off to purchase the proper one now. I know I could make my own but I much prefer the security of the original design. https://cimg8.ibsrv.net/gimg/landrov...1c203c4f60.jpg https://cimg6.ibsrv.net/gimg/landrov...a64ad97bfc.jpg https://cimg8.ibsrv.net/gimg/landrov...aa81c4f833.jpg |
Thanks for doing this write up. Looking forward to your additional pictures. Please post source and part numbers for the battery mount that works as I’m about to install a second battery. Appreciate the inline photos too! |
The battery hold-down is YJF500100R. Some people sell them with the long bolts, some not. On eBay a kit is a whopping $50. Total rip-off. But there are not a ton of reliable sources in the US. Im still looking around for a better price.
edit: Bought the one on eBay. They have several available. All new with bolts. |
Using that part number, I found a listing that I had seen earlier at BPUtah for the bracket and both bolts for LHD for $40 plus shipping. Is that same thing you Found on eBay?
British Parts of Utah https://cimg0.ibsrv.net/gimg/landrov...05d737413.jpeg |
Wrong bracket, note the last letter of the part number. But yes, they have an eBay store and that’s were I just bought mine from. Says seller is away now so not sure when it will ship. https://www.ebay.com/itm/Land-Range-Rover-Sport-LR3-LR4-Clamp-Bracket-for-Second-Auxiliary-Dual-Battery/292322149535 |
So while I was waiting for my exhaust to cool, I took a few minutes to install the battery itself. Thus, not much to report right now. The battery is shorter than stock, so I picked up a couple thick nylon washers that worked perfectly! I also installed a bit of foam. It compresses a lot. So it sorta acts as a cushion pad but also to prevent the battery from shifting. So now the battery is very well secured. I dont feel it would hit he master cylinder at all. Coming up soon will be the solenoid and cable installation.
https://cimg7.ibsrv.net/gimg/landrov...875e231c33.jpg https://cimg8.ibsrv.net/gimg/landrov...f9e6ddcc56.jpg https://cimg9.ibsrv.net/gimg/landrov...adc2257925.jpg |
Looks good! I installed my National Luna kit this weekend. I didn’t have good luck with the OEM hold down. The Odyssey 34r that I bought didn’t have the same shape to the top. I need to run the the auto parts store and see what I can find that may work with the limited space under the cover. |
If you are handy with basic metal work and can find metric threaded rod, I have seen some use a simple piece of flat metal. Inch or two wide. Drill a couple holes and then just a couple nuts on the top end of the thread. Paint it black to look pretty. Simple but effective and very low profile.
Nice write up |
You know that the CCA rating means little when using it as an auxiliary, what is the amp hour rating of the battery ?
