Lr3 rotor/brake recommendations
I'm educating myself on this but can use some direction...It looks like I might have to consider new rotors as my steering wheel shakes like crazy while breaking..anyway, if it does happen to be the rotors I would like to replace with quality parts...any recommendations. So far, i see these:
LR3 Land Rover Discovery 3 Brake Rebuild Kits: Order Brake Kits Online
They seem much pricey compared to other kits...worth it? Anything else recommended.
I used Raybestos
(F) 980351 Raybestos 980351 Disc Brake Rotor | eBay
(R) 980345 Raybestos 980345 Disc Brake Rotor | eBay
and Bosch Pads
(F) BP1098 Bosch BP1098 Brake Pad or Shoe Front | eBay
(R) BP1099. Bosch BP1099 Brake Pad or Shoe Rear | eBay
I purchased mine through Ebay and these exact sellers. Fast shipping and no problems.
I have had them on the for about 3 months now with no complaints.
and Bosch Pads
702LR3 (05-13-2021)
Rear brake pads & rotors
REAR BRAKE PADS & ROTORS for LR3 2007
Per Slickzero76's recommendation, I have order the Bosch's pad and Raybesto's rotor. Parts cost total come to only $174.
Does anyone know why LR dealership wants $900 to replace my rear brake's pads and rotors - when parts only cost $174??
Thanks,
Mai-ILLINOIS
Thanks,
Mai-ILLINOIS
+1 On the EBC. I use EBC drilled/slotted and EBC Green stuff pads. My next set of pads will be yellow stuff, only because I wanted to try them.
I got 80k and had some life left when I swapped out the first set. They hold up well, and I am happy with them. You need to have them turned very lightly at each brake pad fitting or you are likely to get brake fade/pulsing.
Thanks,
Mai-ILLINOIS
Thanks,
Mai-ILLINOIS
Checked into front and rear brakes for '06.
Independent with aftermarket parts-$1500.
Dealer with Rover parts-$1350.
Go figure??
Genuine LR rotors are about $100/piece online (total = $400) - I like these because they don't rust like other rotors are prone to do...
Some nice Akebono brake pads are about $75/set IIRC (total = $150)
EPB shoes (if you need to do them) probably run in the $60-80 range
Indy labor would likely be somewhere in the neighborhood of 3 hours at $80-100/hr (total = $300)
So... buy your parts online, and pay the shop to install them if you don't want to do it yourself. You should still be able to get it done for <$1000 including the parking brake shoes.
