LR3 Suspension Faults w/troubleshooting updates
Chris,
I'm not certain which supplier is best. I picked up a new-old-stock relay that said Ford on it. I tried it: didn't make a difference.
UPDATE:
- I removed the 70A relay & directly wired across the ports via a wire with a 30A in-line fuse. Compressor turned on, no problem.
- Vehicle still refused to raise. I let compressor run for 1 minute, then shut it off. Let it cool for 5 minutes, then ran again for 30 seconds. Still, the vehicle would not raise.
- This morning, I start the vehicle. All of a sudden, I hear the compressor kick on. No suspension fault is displayed on the dash. Vehicle does not appear to be lifting.
- As I'm driving, out of my neighborhood, the amber suspension fault turn to red when I exceed 30 mph. I pull over & hop out. Lo and behold, the suspension had raised!!
WTH?!?! I'm certainly baffled. I've ordered the GAP IID Tool. It should arrive next week.
UPDATE:
Chris Gatan (02-18-2021)
Update* used gap tool to deflate air from system. Replaced the front air valve. Iam no longer getting the original C1130 code but am now reviewing a U0132-87 (28) Lost communication with ride level control module - Bus signal/message failure - missing a message. And the vehicle front is staying at "standard" ride height. Rear is as was previous to repair. I was going to get the front calibrated but am concerned that the new code is the problem not calibration? Any ideas and thought are appreciated
.m. thanks for the help. Will calibrate back to original specs
i think there are 2 gap tools available. The one I have won't calibrate until "unlocked" from gap -diagnostics. The other gap tool is a shop version open to all calibration on multiple vehicles
Well, almost...
...where did you get this GAP tool? I'm guessing it's 2nd hand. I'll tell ya why, if that's the case.
When you buy the tool you have to register it, including your VIN. That's when all features are enabled. You can add other VINs too. I have two LR3s and my IIDTool works on both because I added a second VIN.
...and yes there is a "pro" version that allows for use on any VIN.
Does the user manual give (3) different ways to calibrate? Looking at page 110 under "app sensor calibration" and I believe this is the way I need to go considering I deflated system without taking measurement s? Please confirm. Thank you 🙏
