Many ECU Faults LR3 not starting
Hello-
I am looking for some insight into a odd situation regarding my 2007 LR3 4.4. I was leaving town for the 4th of july when various ECUs started to shut down on my LR3. It would start by the door locks clicking, followed by ending of the Radio/entertainment, then AC, etc. I have the GAP Tool and ran the Faults. Almost all of them showed up, and I was able to clear all but the following. Engine Petrol - U0167-00 (68) Lost communication with vehicle immobiliser control module Parking Aid - U0300-55 (2F) Internal control module software incompatibility - System programming failure - is not configured Transfer Case - U0155-87 (2F) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message Transmission - U0155-87 (2F) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message Tyre Pressure - U0300-00 (2F) Internal control module software incompatibility - U0416-00 (AF) Invalid data received from vehicle dynamics control module Vehicle Dynamic - U0155-87 (2B) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message I shut off the Rover and then it would not start again- and all the fault codes returned. I was able to restart it, i dont know how, and head back home. It is currently at my mechanic, but i fear because of the Electrical Nature, it will cost a ridiculous amount just to find. Any insights or experience with these electrical gremlins? Thanks, James FYI These are the faults that came up before trying to clear them. Audio System --> U0300-55 (2B) Internal control module software incompatibility - System programming failure - is not configured Body Control --> B1A00-16 (2F) Control module - General electrical failure - circuit voltage below threshold --> U0155-87 (6C) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message Engine Petrol --> U0167-00 (68) Lost communication with vehicle immobiliser control module Instrument Pack --> U0010-88 (2E) Medium speed CAN communication bus - Bus signal/message failure - bus is off --> U0132-87 (2E) Lost communication with ride level control module - Bus signal/message failure - missing a message --> B1A87-68 (28) Battery disconnection/electronic control unit reset - Algorithm based failure - event information Parking Aid --> U0155-87 (2F) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message --> U0140-87 (2F) Lost communication with body control module - Bus signal/message failure - missing a message --> U0300-55 (2F) Internal control module software incompatibility - System programming failure - is not configured Parking Brake --> U0101-87 (A8) Lost communication with transmission control module - Bus signal/message failure - missing a message Steering Angle --> U0122-87 (2F) Lost communication with vehicle dynamics control module - Bus signal/message failure - missing a message Transfer Case --> U0155-87 (2F) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message Transmission --> U0155-87 (2F) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message Tyre Pressure --> U0300-00 (2F) Internal control module software incompatibility --> C1A64-93 (68) Spare wheel tire pressure sensor and transmitter assembly - Component failure - no operation --> U0416-00 (AF) Invalid data received from vehicle dynamics control module Vehicle Dynamic --> U0155-87 (2B) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message Ventilation --> B1B74-00 (6C) Front foot-defrost mode stepper actuator --> B1B75-00 (6C) Front foot-face mode stepper actuator --> B1B76-00 (6C) Front left air blend stepper actuator --> B1B77-00 (6C) Front right air blend stepper actuator --> B1B82-00 (6C) Rear air distribution stepper actuator --> B1B83-00 (6C) Rear air blend stepper actuator |
what was your battery voltage at?
(Post 735480)
My mechanic said that it could be 4 possible CAN Bus issues. Talking 700ish - I hope it is something simple like the brake light issue. |
Are the carpets wet at all?
No the carpets weren't wet, however, I had removed the Passenger side A pillar molding to see if i could run a wire from roof rack lights through it. I replaced it, not running any wire or anything (not touching any battery/or wires just looking) then ran the Landy through the brushless car wash. If there was any water I would assume it would be most likely through that entry point. High pressure water and fiddling with the molding-
**UPDATE** ECU Faults & LR3 Not Starting CAN Bus Comms
Just spoke to my Mechanic and it appears to be CAN Bus issue with the instrument cluster. There are intermittent failures/comms issues. So it will need to be replaced and reprogrammed. He Stated that he has a vendor/person in TX and can do a swap from my understanding. Def going to do some digging/research for issues such as this.
Thanks! James |
Possible I suppose. The clusters on these truck do seem to have a failure rate. Something I have never, ever seen in any vehicle I have owned before. But I know every once and a while someone ends up with a cluster issue. I also recall one case where a connector came loose, so that is even a possibility to consider.
Keep us updated. |
