Many ECU Faults LR3 not starting
Old Jul 7, 2020 | 05:59 AM
jbullock78's Avatar
Default Many ECU Faults LR3 not starting
Hello-
I am looking for some insight into a odd situation regarding my 2007 LR3 4.4.
I was leaving town for the 4th of july when various ECUs started to shut down on my LR3. It would start by the door locks clicking, followed by ending of the Radio/entertainment, then AC, etc.
I have the GAP Tool and ran the Faults. Almost all of them showed up, and I was able to clear all but the following.
Engine Petrol
- U0167-00 (68) Lost communication with vehicle immobiliser control module
Parking Aid
- U0300-55 (2F) Internal control module software incompatibility - System programming failure - is not configured
Transfer Case
- U0155-87 (2F) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message
Transmission
Tyre Pressure
- U0300-00 (2F) Internal control module software incompatibility
- U0416-00 (AF) Invalid data received from vehicle dynamics control module
Vehicle Dynamic
- U0155-87 (2B) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message
I shut off the Rover and then it would not start again- and all the fault codes returned.
I was able to restart it, i dont know how, and head back home.
It is currently at my mechanic, but i fear because of the Electrical Nature, it will cost a ridiculous amount just to find.
Any insights or experience with these electrical gremlins?
Thanks,
James
FYI
These are the faults that came up before trying to clear them.
Audio System
--> U0300-55 (2B) Internal control module software incompatibility - System programming failure - is not configured
Body Control
--> B1A00-16 (2F) Control module - General electrical failure - circuit voltage below threshold
--> U0155-87 (6C) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message
Engine Petrol
--> U0167-00 (68) Lost communication with vehicle immobiliser control module
Instrument Pack
--> U0010-88 (2E) Medium speed CAN communication bus - Bus signal/message failure - bus is off
--> U0132-87 (2E) Lost communication with ride level control module - Bus signal/message failure - missing a message
--> B1A87-68 (28) Battery disconnection/electronic control unit reset - Algorithm based failure - event information
Parking Aid
--> U0155-87 (2F) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message
--> U0140-87 (2F) Lost communication with body control module - Bus signal/message failure - missing a message
--> U0300-55 (2F) Internal control module software incompatibility - System programming failure - is not configured
Parking Brake
--> U0101-87 (A8) Lost communication with transmission control module - Bus signal/message failure - missing a message
Steering Angle
--> U0122-87 (2F) Lost communication with vehicle dynamics control module - Bus signal/message failure - missing a message
Transfer Case
Transmission
Tyre Pressure
--> U0300-00 (2F) Internal control module software incompatibility
--> C1A64-93 (68) Spare wheel tire pressure sensor and transmitter assembly - Component failure - no operation
--> U0416-00 (AF) Invalid data received from vehicle dynamics control module
Vehicle Dynamic
--> U0155-87 (2B) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message
Ventilation
--> B1B74-00 (6C) Front foot-defrost mode stepper actuator
--> B1B75-00 (6C) Front foot-face mode stepper actuator
--> B1B76-00 (6C) Front left air blend stepper actuator
--> B1B77-00 (6C) Front right air blend stepper actuator
--> B1B82-00 (6C) Rear air distribution stepper actuator
--> B1B83-00 (6C) Rear air blend stepper actuator
Old Jul 7, 2020 | 04:43 PM
what was your battery voltage at?
Old Jul 7, 2020 | 04:50 PM
jbullock78's Avatar
The Voltage was 12.5- then when running it when to 13.5. On the low end from what I gathered. So I got a new Battery just in case (figured couldnt hurt anyhow). Normally the voltage is around 14.1 or so.
My mechanic said that it could be 4 possible CAN Bus issues. Talking 700ish - I hope it is something simple like the brake light issue.
Old Jul 7, 2020 | 05:52 PM
DakotaTravler's Avatar
Are the carpets wet at all?
Old Jul 8, 2020 | 07:03 AM
jbullock78's Avatar
No the carpets weren't wet, however, I had removed the Passenger side A pillar molding to see if i could run a wire from roof rack lights through it. I replaced it, not running any wire or anything (not touching any battery/or wires just looking) then ran the Landy through the brushless car wash. If there was any water I would assume it would be most likely through that entry point. High pressure water and fiddling with the molding-
Old Jul 8, 2020 | 07:12 PM
jbullock78's Avatar
Default **UPDATE** ECU Faults & LR3 Not Starting CAN Bus Comms
Just spoke to my Mechanic and it appears to be CAN Bus issue with the instrument cluster. There are intermittent failures/comms issues. So it will need to be replaced and reprogrammed. He Stated that he has a vendor/person in TX and can do a swap from my understanding. Def going to do some digging/research for issues such as this.
Thanks!
James
Old Jul 8, 2020 | 09:12 PM
Possible I suppose. The clusters on these truck do seem to have a failure rate. Something I have never, ever seen in any vehicle I have owned before. But I know every once and a while someone ends up with a cluster issue. I also recall one case where a connector came loose, so that is even a possibility to consider.
Keep us updated.
Old Aug 12, 2024 | 07:14 AM
gmtech's Avatar
any update on this? i am having the exact same issue. drove fine one day next morning no start. hazards flashing door locks cycle. HDC fault message on dash. u0155-87 loss of comm with IPC in the TCM. u0167-00 loss of comm with imobilizer in ECM u0010-88 meduim speed CAN bus in IPC. U0122-87 loss of comm with vehicle dynamics control module in steering angle sensor module. U0155-87 loss of comm with IPC in VDM u0010-87 medium speed bus in audio front control module.
battery is about year old. 12.6 volts before trying to crank. tried to jump start with jump pack and will not start with that either. no carpets wet. was in garage and hasnt been in rain for 2 weeks.
Old Aug 12, 2024 | 11:18 PM
loanrangie's Avatar
Cluster repair or swap, repair the original if you can otherwise you run into trouble with mismatched odometer etc.
Old Aug 13, 2024 | 07:06 AM
gmtech's Avatar
I found clusterfix is there any other USA places that do repairs?
