New product from Proud Rhino! The SYA Off Road Extension Kit
Old 08-21-2015, 11:51 AM
Fivespddisco's Avatar
Default New product from Proud Rhino! The SYA Off Road Extension Kit
I would like to start this new product release with a question:
What is the biggest fear of LR3, LR4 and Range Rover Sport owners who run larger-than-stock tires?
I can hear everyone on the web simultaneously cry out “having my air suspension fail, leaving my truck on the bump-stops”. This is a legitimate fear for anyone using air suspension. Fortunately the engineers at Land Rover built in a safety net with the bump stops. Unfortunately for those with larger tires the bump stops are only effective for tires slightly over stock size.
Running larger tires on your Rover has it’s Pros and Cons.
Pros: You achieve more ground clearance to navigate obstacles more freely and you’ve also made your Land Rover look like a Land Rover should.
Con: A random air suspension failure will leave your truck on the bump-stops. When this happens with larger tires, you're stuck. Your tires will be so compacted into the wheel wells that you will be immediately immobilized. Now you are stuck somewhere on the trail with a 7,000 pound anchor that doesn’t roll. Good luck getting your truck to budge without damage.
Here at Lucky 8 we’ve teamed with Proud Rhino to remove that Con from the list altogether by creating the bump-stop spacer kit. When the airbags let go, these spacers will be in place to keep your truck from completely sinking to the ground and leave you enough wiggle room to be able to roll out of the woods, or parking lot, or wherever your Land Rover decides to fail.
These spacers have been rigorously tested here @ Lucky 8 on our Project LR3. Some of you may have seen them on the truck at some of the events across the country we tested them at and we can truly say that this is a must-have for anybody who runs the larger tires. Not only are these essential when running the larger tires, but they also provide a more comfortable ride when running a lifted truck. The lift rods essentially trick the airbags into filling with more air. This gains height on the vehicle, but it also stiffens the bag and creates a hardened ride. With these spacers the truck will remain lifted with your rods but the bags will not have to inflate as much, leaving more room for the air spring to do it’s job and create a more comfortable experience for everyone in the truck.
For pricing and more info please have a look on our site.
Lucky8llc.com - Proud Rhino Products for Land Rovers
Attached Thumbnails New product from Proud Rhino! The SYA Off Road Extension Kit-unnamed-26.jpg   New product from Proud Rhino! The SYA Off Road Extension Kit-unnamed-29.jpg   New product from Proud Rhino! The SYA Off Road Extension Kit-unnamed-30.jpg   New product from Proud Rhino! The SYA Off Road Extension Kit-unnamed-32.jpg
Old 08-21-2015, 02:50 PM
morrisdl's Avatar
Looks great! Just two questions:What the price and installation effort?
Old 08-24-2015, 02:55 PM
Ian_Barry's Avatar
5th Gear
After reviewing the material at Lucky8 I have a few questions:
*How is the length of the limiting strap determined?
*Where is the strap expected to run?
*Are the bits of pipe to extend the air lines?
*Is there a part of the build thread that includes installation of these/development process?
*Aluminum or Steel?
Thank you in advance for taking the time to answer these questions,
Ian
Old 09-06-2015, 10:57 AM
techniq808's Avatar
Certainly intesrested. Ditto the questions above.
Old 10-30-2015, 01:57 AM
DavC's Avatar
Looks like a very good product in an area that will become a problem as more guys get into really tuning these things.
Old 02-13-2016, 05:29 PM
techniq808's Avatar
Installed mine yesterday along with the Proud Rhino rods. New 32's installed today - Cooper Discoverer RTX (LT275/65/18) - NTB has them buy 2 get 2 free with their Value installation pkg (still came out cheaper than buy all tires).
Thanks Lucky8! This helped the pros far outweigh the cons in deciding to go with larger tires.
Picture and more details over on ExPo
Also anyone know the lift on the Proud Rhino rods? Most kits are 2.5", but their site says 3".
Old 02-17-2016, 11:35 AM
WNYErikDiscoII's Avatar
Former Sponsor
They are 2.5". Where does it say 3" on the site?
Old 02-18-2016, 10:06 PM
techniq808's Avatar
On the proud-rhino.com site: Lift Rods for Land Rover LR3 (Discovery 3) | Proud Rhino
"Description: The all-new LR3 lift rods are high quality height sensor rods to lift your Land Rover. Gain 3 inches clearance amd improve off road performance of your LR3.
Proud Rhino lift rods are the best and highest quality suspension mod available. ..."
Old 04-13-2016, 08:51 AM
techniq808's Avatar
Ran the Extension Kit this past weekend at Uwharrie and it was great. What i like most is driving on the hwy in Normal height with the rods, feels very close to stock.
jafir (04-14-2016)
Old 08-14-2017, 01:20 PM
cybercop's Avatar
Does anyone think there would be a problem with 285/65r18 BFG ko2
Quick Reply: New product from Proud Rhino! The SYA Off Road Extension Kit
