Newb questions
Old 03-07-2010, 06:53 PM
CopperMtnGuy's Avatar
Default Newb questions
1. How many quarts of oil are needed in the 4.4L?
2. Is Synthetic required?
3. How hard are oil changes (filter location mainly)
4. Anything else I should know?
Thanks in advance.
Old 03-08-2010, 12:20 AM
bribake's Avatar
8 L's, I would use Synthetic, 3 not sure, 4-welcome to the club
Old 03-08-2010, 01:10 AM
geotrash's Avatar
Thanks in advance.
On the oil change, here's a nice guide:
http://www.roverparts.com/Techtips/Oil_Change_LR3.cfm
Capacity is 8 quarts. Recommended viscosity is 5w-30. I like Mobil 1 synthetic and it can be had at Wal Mart for $21/5 qts.
Dave
Old 03-08-2010, 05:55 AM
Thanks!
Old 03-09-2010, 03:29 PM
Also, what diffs do we have? And what is the max tire rating for them?
Thanks for answering my newb questions...
Old 03-09-2010, 11:06 PM
geotrash's Avatar
They're all the same unless you have the HD package which has an electronic rear locker. No idea of the max tire size, but the proper lube can be found here:
http://www.britishpacific.com/BPSite...er_fluids.html
Dave
Old 03-10-2010, 06:07 AM
Thanks...
Old 03-10-2010, 05:41 PM
I got a message on it that says "Over Speed Warning"...what can I do to get rid of it, or reprogram it to a higher speed?
TIA...
Old 03-11-2010, 07:36 PM
I fixed it...getting great MPG...16.6. Not bad bad for a V8 4x4...
Old 03-11-2010, 09:00 PM
davidfkon's Avatar
TIA...
drive faster and ignore it . . . or take the bugger off-road and you will be much more happy!
Quick Reply: Newb questions
