Non Premium Fuel Argument
Old 11-04-2019 | 07:16 PM
LR Techniker's Avatar
Originally Posted by Sixpack577
Yes, detonation(knock)is bad.
But, since it has knock sensors, then it's designed to retard the timing accordingly.
So then there should then be no detonation, and no problems.
Many D2 owners here have reported running 87 octane for years, without issue.
In order for detonation to be detected, it has to occur. So yes, knock sensors and computer programming will reduce engine knock, however it still occurs.
Also, the computer combats detonation by retarding timing. Pulling timing reduces power and efficiency. That hurts performance and fuel economy. Perhaps by negligible amounts, but it occurs no less.
Old 11-04-2019 | 08:45 PM
Sixpack577's Avatar
Yes...but where are all the blown engines as a result then??
Low octane in, detonation, knock sensors pick it up, ecu adjusts in real time, timing retards, detonation now not happening.
A Very small amount of stress and wear.
Engines are wearing out from the first time they are turned over.
Detonation causes wear, absoloutely, as compression is igniting the lower octane gas before the spark can, while the pistons are still traveling up they are prematurley getting force to push them back down.
I get it. I understand engines.
My original question was, how can an engine with knock sensors destroy itself from detonation?
As long as it's functioning normally...it can't.
Old 11-04-2019 | 09:22 PM
robertf's Avatar
if the detonation is from the combustion shockwave you are correct, but if its from hot spots in the cylinder head then the ecu cant do anything about it. Probably not as big a deal now with lower btu ethanol diluted fuels, but a legit concern in the unleaded e-00 fuel days with a 60s era combustion chamber and no egr
Sixpack577 (11-04-2019)
Old 11-05-2019 | 11:29 AM
Read my last sentence: "Perhaps by negligible amounts...". I don't think its good for the motor, but I don't think its causing them to explode either.
Sixpack577 (11-05-2019)
disconic
09-05-2019 03:48 PM
Rock Sing
12-27-2013 06:58 AM
bmerritt547
10-09-2012 11:20 PM
Phototone
03-31-2008 12:52 PM
Chrisinhouston
12-19-2007 10:20 PM
Quick Reply: Non Premium Fuel Argument
